hotter badatel
Založen: 04. 12. 2004 Příspěvky: 141 Bydliště: Lithuanian Telefon: M55 47266.46 SMM
Zaslal: pá říjen 30, 2009 8:16 pm Předmět: USB to COM |
My new laptop doesnt have a com port, but I need it to patch my M55, so I got "USB to COM" cable, but it doesnt want to work. Is it possible to make it work with M55 patching cable? How? Maybe someone tried such cable and know?
Maybe such cables are just for old printers? _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
yaqwsx táta fóra
209083.66 SMM
Zaslal: pá říjen 30, 2009 9:38 pm Předmět: |
Have you tried the cable with another HW? For example printer or something like this. Because it can be wrong driver or someting and cable does't work for all.
Another solution: Use a docking station for NTB. Docking stations usually have COM port. With this port it will work for 100 %. _________________ Děda vševěda, bůh(neplést s Bůh) == Google......
JFGI - Just Fuckin' Google It
hotter badatel
Zaslal: so říjen 31, 2009 8:17 am Předmět: |
I think I dont have any HW with COM port to try... I installed some kind of drivers, maybe I need to configure them?
Options screenshot
(I tried it on windows 7 and windows XP) _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
cyber-j mecenáš
Založen: 16. 10. 2004 Příspěvky: 107 Bydliště: teraz Praha
3.28 SMM
Příspěvky na SM: 1460,- |
Zaslal: so říjen 31, 2009 10:28 am Předmět: |
I think the driver is OK. Try to set lower settings, as it is writen, it is better for correction connect problems. Maybe it will help. _________________ M35->ME45i -> M65@CX70 -> M75 ->
Utano Barrier T180 -> Cat B15 |
hotter badatel
Zaslal: so říjen 31, 2009 1:19 pm Předmět: |
Nope, not helping any other ideas?
Is there x55 usb cables for patching? _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
hotter badatel
Zaslal: po listopad 02, 2009 12:13 am Předmět: |
Would such cable work with M55 patching:
or this
found it here http://sx1.oslik.ru/werefox/circuit/cable55.html _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
hotter badatel
Zaslal: st listopad 25, 2009 7:42 pm Předmět: |
I got rid of my "made in china" usb to com cable, so I could buy a new one but only if that cable would truly work with DCA-510com cable, anybody know such cable?
Or any one have scheme of x55 usb cable for patching/data transfering? _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
hotter badatel
Zaslal: út květen 04, 2010 5:37 pm Předmět: |
hotter napsal: |
Just made usb cable by this schema. Works good on m55 and cx70, shows DCA-510!
Soldering was really hard because chip is only 5x5mm, but I made it! _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
